Another a/c magnetic clutch test
  • Another a/c magnetic clutch test
    I recently posted that the coil of an York compressor would hold 70 pounds of weight. Today I put the clutch back together and measured the torque to make it slip when energized. It was about 50 foot pounds. I am know thinking about hooking this up on my lathe. What is the torque on a 1 hp motor?
    If 1800rpm then about 2lb ft,if 3600 then about 1lbft.
    Remember those car ac units require about 5hp to operate,so little chance of it being overloaded.
      I have been using one of those on my lathes for years. They work great. I run the V belt just a little loose which takes up the shock load when the clutch engages.
        I am finding this to be an interesting subject. I do have a few questions though.
        How are you going to bring power to the spining magnet?
        What are you using as a power source? I have figured it is 12volts but how many amps and what is providing them?
        If you have any pictures once you are done and as you go i would like that...
        Rob
          Rob, the magnet don't spin. The coil takes 3 to 4 amps at 14 volts. Here is a pic of one taken apart.
          http://photobucket.com/albums/v110/t...t=DSC00347.jpg
