I have 15MM 1.0 tap for a special job. I can't find a chart anywhere that gives the drill size. Every chart I've found goes from 14MM to 16MM. Why do they all skip 15MM ??
JL.................
The ISO standard apparently includes the concept of "preferred" sizes and pitches. Sometimes the pitch will be such that it makes for a weaker fastener (or so I was told) and so those are normally skipped. Those sizes are still in the ISO standard, they are just part of a "less desirable" class.
Some of the metric minded folks are convinced that you should never, ever use the size/pitch combinations that are not in the preferred group. Others point out that you can make a valid metric thread using any diameter and any pitch as long as it is measured in mm and meets the standard for the thread form.
Dan
