All,
I have a broken shaft from a gearbox with a flat root involute spline. Through reading this forum as well as other sources I believe it's a 16/32, althought I haven't done any serious measuring to verify. The shaft OD is .625 on the money. Roughly measuring with calipers the internal spline ID is slightly over .500. I think it's a side fit because I can see daylight between the major diameters when the broken piece is slid into it's mate.
I've poked around the interweb for a cutter, but I haven't found anything less than 12 teeth. Any leads on where I might find such an animal?
Thanks,
Aaron
Thanks,
Aaron
