What's better, mounting it to the front or the back of the table? I'm wondering if losing the ability to mount something off the front of the table is a bigger deal than losing some Y-axis travel.
I'm replacing the DRO on my old Bridgeport J-head Mill (42" table, long travel knee) because the PO disabled the power feed stops and had the x axis mounted offset to one side and when I fed the table to one side the reader head crashed into the end of the scale destroying it (and a whole new DRO assembly was cheaper than just replacing the broken vintage Mitutoyo parts).
The original X axis scale was mounted in brackets made to fit the table front T-slot, I didn't even know there was a slot under them and there were a few times I would have used it- the one that comes to mind was when I was machining the throttle body mount on the front of an intake manifold plenum and it was just too long to mount on top of the table, hanging it off the front of the table would have been REALLY nice (I did something somewhat sketchy with some angle plates hanging it off the back of the table). I'm not sure if it was more convenient or in the way on the front of the table- it got in the way, but it was nice to have a flat surface in front of the table to set stuff on that was not using up table realestate. I'm also not sure if I can use the brackets that were there, all the original hardware is much larger than what came with the new scales (mostly 1/4-20 vs M4 and M5), and I'm not sure if I can drill out the mounting holes in the scale's reader head large enough to use them (the spacing appears to be standard).
Mounting it on the back appears to be a piece of cake, just locate and drill 4 holes, maybe a few more if I mount the supplied guard. OTOH, right now the y axis can travel till the table is against the column. The scale use up over an inch of space, and If I mount the guard it will use up close to 1-1/2" of the Y-axis travel.
Thoughts? Anything I'm overlooking?
