The 14x40 grizzly manual shows the forward bearing is a 7212D. The large one.
Ordered both rear and front bearings. Received forward MRC 7212D angular contact bearing.
Today, removed the spindle and discovered the front is a tapered roller bearing w/ the raceway pressed into the main casting.
Whats up w/ this ? Should I use the angular contact bearing ?
This one piece bearing is going to be a real PITA to install.
