Help identify hydraulic cylinder
  • #31
    Originally posted by Axkiker View Post
    Yeah that would be great. Would love some dimensions etc of the material used. If you could also note the model I can look it up online as well and get an idea of construction.
    Thanks
    Model is a 50 H-
    http://www.dakecorp.com/products/hyd...ated-press-50h
    • #32
      So ive seen this before but it still leaves me with questions around the size / type of materials used. Not necessarily the size of the machine but the size of the steel used. Also does it not look a little lightly built. I mean if its rated for 50T surely its been tested to 75 if not 100 ton for safety. I cant imagine that unit taking that much pressure but im definitely not educated on the subject.
      • #33
        The one we have at work has been in use since it was new in 1938?So it's a successful design.The frame does load up near 50tons,but all frames will unless they are massively overbuilt. IIRC the cross members are 10" x 25lb/ft channel which is a fair bit heavier than a HF bottle jack press.
