In repairing my Baldor VM3559T, I sleeved and re-trued the shaft, installed new bearings, milled a new key way for which I had to removed and re-weld the internal fan, reassembled the whole affair and it does not like to run at all.
In starting on my mill VFD, which is in excellent shape, the motor sort of bucks & snorts at low Hz, smooths out, bucks , snorts & shakes again up around 25Hz then rips up to top.
Then it faults the VFD with E7 which is "DC bus voltage exceeds a threshold, due to regenerative energy from motor."
Say what???
The thing ran like a champ when pulled from service and, no insult, these motors aren't a complicated mechanical assembly.
VFD is fine, runs the mill perfectly, the motor was wired for testing correctly...any ideas?
What's regenerating in the motor?
Say what???
