Hey guys,
I've been looking at mills on the classifieds, but I'm plagued with the typical issues like how will I get it home, move it, etc. And with only a 7.5 foot ceiling in the garage, height and top access is a concern. But a major issue I can try to get to the bottom of ahead of time is whether or not my garage floor can handle it. The last thing I need is buckling my house in half under the weight of a milling machine or large lathe.
My garage is below my house, which is a raised bungalow. 20.5 x 20.5 feet, a single piece of concrete with no relief cuts or anything. It might have rebar in it as one small spot has spawled a bit and some rusty colouring is showing, so I'm making a guess there must be some steel in there. Surface isn't looking great but it's alright as long as you aren't rolling anything around on cast iron wheels.
One thing I don't know is how thick it is, and I don't really know how I could find out. I could probably try to scoop the dirt out between the garage entry and the asphalt driveway and see if I can feel the bottom edge with a small hooked implement. Otherwise, don't know how I would judge it.
Does anyone have stories and experience with evaluating their place for heavy machines? I'd love to hear how anyone else went about it, and what the long-term results were.
Thanks gang
Thanks gang
