Find and check the ground between the engine block and the frame, I have had more of those corrode with age, even though I live in the desert, and this causes not only problems with charging but with the electronics in newer vehicles.
Most vehicles have only one ground strap from the frame to the block, if any, and I have added a couple of more on all my vehicles (1970-1/2 Trans Am, 1989 F150, 1995 H1 HUMMER (it already had two) and a 2001 PT Cruiser) and after doing so on the Trans Am , F150 and PT Cruiser, noticed a decrease in voltage drop to the battery from the alternators, and a decrease in noise on my HAM radios in them as well.
On my late wife's PT Cruiser, it solved the erratic shifting problem the transaxle was having that the dealership couldn't find.
Motor mounts don't provide all that great a ground path , especially the newer ones with polyurethane bushings I have found, so having a good solid DC ground between the block and frame has made a difference for me, your results may vary.
The 1995 H1 Hummer has the original Interstate Megatron Plus batteries in it, 22 years and 91,000 miles old, I test them once a month with HF's top dollar 500 Amp load tester(was a gift) , and a similarly rated old SUN tester, they both read almost identical values and show both batteries are still in great condition.
The Trans Am has a 9 year old Everstart MAX in it, turning over a 600+ cubic inch 13.5 :1 Compression big block, and it's still doing fine.
The F150 and PT both have the Everstart Max batteries as well, both are 7 years old, that's pretty good life here in the desert for a car battery.
I do keep after them , keeping the cells filled to the proper level with distilled / deionized water, and using both a hydrometer and the load testers to check the state of charge, mostly because I am retired and now that my wife of 42 years is gone, I don't have nearly enough to do to keep me occupied..... other than, that is, dodging the widows, divorcees, and spinsters around here who seem to come out of the wood work when they hear there is a single guy with all his own hair, teeth and two or more nickels to rub together in town.........fortunately the cat likes tuna noodle casserole...........
