To start with I discovered that all of these machines are not identical. Depending on the date they were built and the company they were built for. So if you have one it may not be exactly the same as what I am describing even though it is the same model.
We knew before I bought the power feed that the gear would not fit right on the end of the X axis leadscrew and a hub would have to be machined to adapt it.
To start with I found that the end of the mill table was too thick for the small bracket to go over it. Everything else looked like it was doable so I disconnected the leadscrew from the table by removing both end brackets and slid the table far enough to the right to enable me to take a cut off of it with the mill. Now the small bracket will fit over the end.
