not the end of the world, but annoying problem from a coolant pump. am hoping someone has seen this before / has a fix?
OEM pump on a Schaublin 13. I recently cleaned the system (when I got the mill). Fresh coolant, no lumps.
It's piped vertically up the back of the machine, over the head, and down to the table/spindle. It's rigid pipe most of the way, then there's a valve I use to control coolant flow, then maybe 20" of metal flex tube that ends in a nozzle.
I keep the ball valve ~25% open as the coolant pump can deliver a lot more flow than I need.
First, when I turn the coolant on, no matter how the valve is set (unless it's closed of course), I get a blast of coolant that must be going Mach 5. I swear if it's pointed at my vise it could knock it out of alignment. water jet cutting has nothing on this.
Initial surge makes such a mess it's become second nature to point it down into the base of the machine, at the coolant return, every start-up.
Anyway, once that first blast settles down, I set the ball valve to the flow I want.
After that the flow slowly diminishes and I have to constantly open the ball valve to keep up with the cut; the 'stream' starts to miss the mark, so i open more and more to keep up with where I want the coolant to go.
After stopping the spindle/coolant to measure, clean chips, etc, the process starts all over again. fiddle with the ball valve, start the machine, initial coolant blast lifts my mill off the floor, throttle down, play with valve during entire cut.
Initially I thought I was low on coolant (ie level gets low, coolant tank can't keep up with what the pump is putting out, flow goes down), but the tank is topped up and I don't have a pool of coolant anywhere that would suggest it's not getting back to where it's supposed to be.
"My Bridgeport never treated me like this"
