The good wife decides she wants a second door in our detached guest apartment. The wall is a redbrick wall and is three bricks thick. The wall is 300mm thick. I hired a firm to come in and do the two vertical cuts I needed. First I cut the inside wall out so I could see what I was getting into. I was very relieved to find 150mm deep studs which meant the brick wall wasn't so think as I thought it might be. There were four power lines in the wall so I had to cut them to get them out of the way.
The firm came and gave me an estimate of what it would cost to make the cuts and I told them to come as soon as possible.
I was really impressed with the saw they used. First they drilled four holes in the wall. Two on each side. THen they trough bolted a linear rail vertically to the wall. The saw then was mounted on this linear rail. All the connections made, water, electricity (380v. 3phase) and the remote control. It was raining really hard so I let them screw a plastic sheet to the soffet. It took about 1 hour for them to get set up and 1 hour to tear down. They also drilled two 200mm holes at the bottom on each side because of the radius of the saw blade not able to cut all the was through. The actual cutting took maybe ten minutes! I was really impressed with the whole process.
The video is about two minutes long.
https://youtu.be/k1-0wZrNZzY
