What do I need to do to cut down the power going into a relay that I think is rated at .5amp 24v from a 24v 20amp power supply? What happens now is the relay activates to the closed position but when the signal is sent to open the relay the relay stays closed. The relay is controlled over an Ethernet cable which is what I need. I think the problem is the relay is controlling two solenoid valves that require just under 1amp each to activate. So in my thinking I might need to run the signal from the Ethernet controlled relay into a higher rated relay to do the heavy lifting on the hydraulic valve.........?????
Or is there some lectrical magic little thingy I could put inline?
It would be no problem to use a PLC to actually control the solenoid valve and run the Ethernet relay power into the input on the PLC with relays that could easily handle the current.
