I was scrounging this last weekend and came across a Boston Gear 700 with a 3 phase motor. (20US dollars) It was vent side down so I figure I would look at the inside before I put it to use.
I removed the motor bolts (4ea) and puled. The motor moves about 1/8 of an inch. I know you can screw up the seals, but would like to pull it apart bum How?
Is there a trick? or something I am missing?
