I need an education outwith metric training , i've had so far
  • #16
    The OD of standard pipe of a certain trade size is standardized, so that pipe of various thickness wall will work with standard fittings. Schedule 40 is probably most common, and the ID may be close to nominal size. There are also Schedule 80 and 160 with thicker walls and smaller ID. This applies mostly to iron (steel) and PVC or ABS pipe, with threaded fittings. Copper tube is similarly standardized for OD, while ID varies with wall thickness (Types K, L, and M).
    USA Maryland 21030
    • #17
      Originally posted by Sun God View Post
      It sure do, otherwise doing internal flow calculations is a right pain in the bum.
      The inside diameter has nothing to do with the thread and the thread is not needed in flow calculations, so naming the pipe thread via internal diameter is stupid, especially since when you measure a threads OD to figure out what it is, yuor calipers will show an actual measurement and not an arbitrary pipe thread size.
      • #18
        It like hard copper is measured ID & soft copper OD.
        country, in easy stages."
        ~ James Madison
        • #19
          The screw in taper air fittings that look like a 1/4" are in fact 1/8" BSPT or BSP if parallel
          Mark
          • #20
            Jakko I am ill educated on pipe sizes not stupid with two degrees from university I think That point is proven. Anyway you will hopefully agree that it is confusing. I have been taught about ID and OD of diameters simply INSIDEL diameters and OUTSIDE diameters I ordered a half inch inside diameter and was very clear about that in the ad it said nothing about pipe measurements. So was I stupid perhaps but I don't think it is justified after all I do this purely for fun not money a hobbyist. Thank you JAKKO. Alistair
            • #21
              You don't have to use ASTM marked pipe so why do you even care. Those standards where set many years ago (100+) and will continue to be used, learn to live with it. By the way yuor is spelled your, unless it is some kind of metric spelling then, OK.
              Southwestern Ontario. Canada
              • #22
                Maybe that's the Finnish spelling.
                • #23
                  What the? Where did I say anything about your stupidity or attacked you in any way?
                  • #24
                    yuor welcome
                    • #25
                      the implication is here
                      • #26
                        I don't read that as directed at you Alistair, just badly-worded. You would not have taken offence if it read 'would be stupid'. A simple second-language error.
                        Monarch 10EE 1942
                        • #27
                          There's metric spelling? Dammit, do I have to learn that too?
                          I can't even remember Imperial spelling, every time I write something I have to ask my wife how to spell at least a couple of words.
                          • #28
                            I posted the thread in view of it naming me if I am incorrect I apologise to jakko of course. Alistair , incidentally I was not really deeply offended .
                            • #29
                              I do this as a hobby also and I am astonished that you, with nearly 15 years on this site, don't seem to have picked up on stuff that's been the subject of many threads.
                              • #30
                                But Arcane, unless someone has a whinge, how can we hope to get rid of anomalies like BWG,SWG,BSP, Cycle threads, BS Gas, BS Brass, BSI, Iso. and all the other ancient ingineering terms unknown to keyboard warriors worldwide. Thankfully, ENGLISH is my first (and only, besides bad) language and I congratulate any not versed in the Queens ENGLISH from attempting to navigate through its intricacies. Sadly some of those it is have difficulties reading and understanding the written word. Was it Mark Twain "Better to be thought . . . . . . "?
                                Regards Ian.
                                Just think what it's going to be like when we exit the EU, back to imperial compasses and rules and twelve pennies to a shilling and twenty shillings to a pound.
                                You might not like what I say,but that doesn't mean I'm wrong.
