ON/OFF Button Placement Convention
Originally posted by garyhlucas View PostIn industry for motors the convention is start over stop. Since the start is normally recessed and the stop extended your hand is covering the stop when pushing start and you can just mash your hand down to hit stop.
Oregon Coast
I like that switch. Of course UK switches are up for off and down for on anything else is weird
"above and behind the lathe" NO. In UK regulations for kitchen wiring require the master switch for the oven/hob to be definitely not behind the hob. Why? Obvious really if there is a problem, eg chip pan fire you don't want to have to reach over it to get to the off switch. Same logic applies to lathe.
If you are getting a NVR switch it is worth finding a version that allows access to the relay feed to wire in additional safety switches. Now I'm not going all ninny about switches on the chuck guard and changewheel guards but suggest a foot bar or other big easy to hit emergency stop.
Schneider Electric has a single hole start stop with indicator light and the start is on top. http://www.alliedelec.com/schneider-...31g5/70380022/
On my lathe, since the I have no clutch, I moved the fwd/rev to the carriage and installed a wide brake/stop pedal. I can just stop with a light press of the pedal or apply the disc brake by pressing harder. Very useful for threading.Helder Ferreira
Setubal, Portugal
Originally posted by Paul Alciatore View PostYes, no definite answer there. They seem more interested in the colors rather than the relative locations. I am stuck with Red and Green buttons as that is what came in the box I purchased.
As to the cost of that IEC standard document, I wonder just how an organization expects people to follow their standards when they price them out of sight. Somehow it just does not seem to make any sense.
From a quick reading, the relative positions do not seem to be stipulated.
When doing a search of photo stock for control panels, all orientations can be seen although start on top seems most common as many on here mentioned.
Back in the pre HMI days, when I was involved with controls, the larger companies ( eg paper and steel) often had their own specs for layout, even down to brands. That was to help the operators go from one process line to another
I was hoping to limit the discussion here to the single aspect of switch placement. I have and am discussing the overall project here on the SB board:
I have been using my SB-9 with just a drum switch for some years now. It is a single phase, 115V, 1/3 HP motor and the drum switch allows me to run it forward and reverse as well as having the center Off position. So it is working. But for some time I have wanted to add an Emergency Stop...
If you read that thread you will see that my first need was for a better way to cut the power off on my lathe bench as the drum switch, which I AM KEEPING at the present time, is too exposed to accidental activation. My second desire was to be able to add some E-Stop buttons at additional locations around the bench for emergencies. My design accomplishes both. Because it will provide the E-Stop function, I also wanted it to be as reliable as possible. And the location of the main control is not important because there will be those additional E-Stop buttons. I will probably be talking about that when the main box is finished and installed.
If you want to discuss the other details I would suggest you to to that thread.
I shall publish the details in some form or another when the project is finished.
Originally posted by Baz View PostI like that switch. Of course UK switches are up for off and down for on anything else is weird
If you are getting a NVR switch it is worth finding a version that allows access to the relay feed to wire in additional safety switches. Now I'm not going all ninny about switches on the chuck guard and changewheel guards but suggest a foot bar or other big easy to hit emergency stop.Paul A.
Golden Triangle, SE Texas
A couple of years ago, two nice young ladies from Health and Safety visited the museum. It was clear they were well out of their depth, most likely being used to inspecting shops and restaurants.
The mill had reasonably accessible stop switches but the Smart & Brown model A was not so good.
We fitted a hinged chuck guard with a cam arrangement working an industrial microswitch in series with the stop switch.
Every time I want to stop the lathe, I just lift the guard about an inch. I love it, it saves 50% of the bending to reach the switch.
As for the H&S ladies, when we told them that we had radium, uranium, thorium and tritium, they went away to do their homework and we haven't seen them since, too much bother maybe.
