I have a twin cylinder compressor, the type with the approx 16 x30 inch tank, motor and head up top.
Bought it lightly used in 87.. Ran it most year round, daily , till 2015.
Did not drain regularly, was lax on that. In the last year or two of regular use it had started to leak, so I would turn it off when not in use. A bit hard to access it, so did not find the leak till my 2015 move.
So now I know it is near the drain end , near bottom, right in the centre of the weld.
Since last year I use it occasionally. Plug it in, do what I need it for, turn it off. After filling , not being used it will kick in after say 10 minutes, due to the leak.
So I can live with it like that. Not sure if it should be welded, or if its probably not worth it.
I dont really feel its dangerous but could be wrong. I use it at most a few hours a week, if that
Any thoughts, or advice.. I do have another too big compresser.
Thanks Guys.
Thanks Guys.
