I had an old cheap floor jack jack in my shed for years, and never used it until yesterday. I jacked the front of my truck up on one side then set blocks under it, but left the jack in place. I left it there over night and today, it was all the way down and now it will not arise and stay up. I don't see oil on the ground, but the jack won't hold itself up.
I look under it, and it is nothing more than a bottle jack configured to work horizontal. The base is made to bolt onto the frame, the valve and plunger on top. So what is in this? A cylinder with packing/seals, seals on the plunger, and a seal at the valve? Can't be much more than that. Any idea where parts could be bought? It's broken now, can't hurt it much more!
I did a search here, didn't see anything about actually replacing parts on a jack like this.
