Cheap is not especially bad in this case. It does not make sense to make a tool that uses $30 inserts to avoid buying a $10 dovetail cutter. If you are only willing to pay $5 per insert, then that becomes a criteria for the search.
I've seen a huge difference in prices between seemingly identical inserts . Imagine paying $154 for a single TNG334 insert. ON SALE! Sure, it's diamond coated, but I will never buy one at that price.
I've used a lot of "cheap" inserts as well as a few expensive ones over the last 15 years. For my use, the cheap ones have worked perfectly well on a benchtop lathe. By cheap, I generally mean a few bucks per insert.
