Need help with disassembly/assembly of Cincinnati no. 3 ? Center
  • Need help with disassembly/assembly of Cincinnati no. 3 ? Center
    The guy I bought my mill from gave me this Center. It had a tin tag on it stamped Cinn. no.3 center and some other numbers but I can't find any corresponding numbers on the center itself.
    Anyway I know part of my problem getting the thing apart is the rust but I have had it soaking in a combination of things to
    free it up/remove rust. Some pieces are free and moving now at this point.
    The Horizontal adjustment does move forward but doesn't seem to want to move backward as easy, I have to seem to push it
    back while I'm cranking the handle. I'm not sure if there is that much backlash or I pushed it out past where the lead screw
    engages and it's not pulling it back or what ? I guess knowing how it should operate correctly would be a big help.
    The vertical adjustment is unstuck, I'm not sure I want to use the word free at this point. The adjustment knob will turn but
    only a little and not a full turn. I tapped on the vertical center section and got movement, at this point the knob turned more freely. When I tapped it back into the place it was before the knob locked up again. I'm wondering if there's a rack and worm gear in there or what ?
    The only disassembly I have done at this point are the nuts, handwheel, and tapered pin in the vertical knob I'm trying to remove.
    Sounds like the centre thread bolt has disengaged, hopefully not stripped, travel on those isn't much from memory, you don't really need it I suppose as your moving the whole thing along the tee slot, mine has a key that sits in the slot sort of arrangement.
    Mark
      Got pics posted
      Ok so I followed george's post on creating an album, then using that URL to paste here but what a PITA.
      I guess this is also a bump.
