Unknown Cutter mount
Yep. Looks like PM may be your best bet. I tried searching by image, phrase and number, to no avail.
Is it an annular cutter?
DanAt the end of the project, there is a profound difference between spare parts and left over parts.
Dan: nope... solid body cutter (like an EM but with a hole in the center); looks like a counter bore.
Illinoyance: It only has 3/8 of body to hold... thought about it often, but just doesn't seem like a good idea.
I have about 20 of them... different sizes. oh.. had them for at least 6 yearsLast edited by lakeside53; 05-31-2017, 11:21 PM.
doing a google image search on "Eclipse Radial drive" (from the post above) brings up a few hits that sure look similar to what you have there.
https://www.google.com/search?q=Ecli...w=1252&bih=616
and here are some holders - starting around page 45
http://www.acerosfortuna.com.mx/asse...20Catalogo.pdf
uh oh...$$$$$ http://www.westtool.com/default.aspx...e=MET+323-2210
much better... http://www.ebay.ca/itm/Metcut-323-22.../132211485734?Last edited by lakeside53; 06-01-2017, 12:11 AM.
