Originally posted by Illinoyance
View Post
If I may criticize...
A collet running true means nothing to the first side, but has a lot to do with eccentricity when the part is flipped end to end for repeat operations . CHECK That!
Part held full length of collet is not an issue IF the part runs true while the center drill is applied. Bumping the part to run true is not unheard of!
Tailstock alignment matters if the tail stock quill is not stiff enough to Cut a center rather than just follow the center of the drill. Some machines are stiff enough, some are not. AS mentioned, easily observed.
WTF is a "rigid spotting drill", If the drilling bit flexes in the cut, it is NOT a spotting drill. ;-)
