Power Hacksaw.
  • Power Hacksaw.
    I recently picked up a 1/4HP 1750rpm motor. I think I will use it to build a power hacksaw. I build one before using my 3d printer and some off the shelf parts. However this time I think I will be keeping the use of plastic parts down to a minimum. The 3d printed hacksaw is actually still functional and has been doing odd jobs here and there but I am not sure I like the design as the motor I am using is running on 19v and is basically overloaded as is with no weight added to the saw.
    In either case I figured I would share the 3d printed hack saw with you guys. I know its not steel, but when you have limited means you make due. Please let me know if this is ok to post otherwise I will remove it.
    https://www.youtube.com/watch?v=wgxpvRvikBg
    one more.
    https://www.youtube.com/watch?v=d8q2HqJ3T_4
    -Bruno
    12x16" Delta 3d printer (Built from scratch)
    Logan 825 - work in progress
    My Blog - http://engineerd3d.ddns.net/
    Youtube Channel - https://www.youtube.com/channel/UCVY...view_as=public
    Instagram - https://www.instagram.com/engineerd3d/?hl=en
    I like the look of it! Nice design.
      A good combination of "off the shelf" and printed parts.
        Nice job on the saw. I don't see any reason it won't cut anything you could cut with the saw by hand.
          GLUG gave detailed pics on the one to build, Sweeeet
          country, in easy stages."
          ~ James Madison
