Been looking at Bang good carbides, the "good" name brand ones are out of my price range. Is there a good all around carbide style, maybe a high relief angle positive one that would be good on a smaller lathe, or have carbides now been heavily designed for specific materials and use. Looking for a good finish on various materials, high cutting rate is less important and I can't afford to stock a bunch of different types for different jobs. I have used TMNG style with mixed results on everything up to now but generally rely on HSS bits which I have a lifetime supply. Just trying to get into the 20th century, the 21st isn't looking so good.
Carbide selection help
Southwestern Ontario. CanadaTags: None
I've some tool holders for CCMT inserts. The CCMT works well as a general purpose cutter. It's a sharper angle than the 60 degree triangles.
One of the nice things about the CCMT insert is that in the right orientation you can turn down the OD by moving right to left and then face the end by moving it straight in with the cross-slide without changing the orientation of the tool.
The designation SCLCR is the "right hand" tool for cutting toward the headstock. SCLCL is the left hand tool for cutting towards the tailstock.
Bankgood has several sets that use this insert for prices under $30. They include left, right and boring bars and the sets are available in several shank sizes.
I still use the Triangle inserts for most of my turning. The right speed, holder and radius lets you do a lot.
DanAt the end of the project, there is a profound difference between spare parts and left over parts.
Originally posted by danlb View PostI've some tool holders for CCMT inserts. The CCMT works well as a general purpose cutter. It's a sharper angle than the 60 degree triangles.
I use either CCMT inserts or the TT style triangle inserts for 99% of my lathe turning these days, with a few exceptions for hard to reach areas where something like a DCMT or VCMT insert works better. And of course the laydown threading inserts, can't be without those.Last edited by Yondering; 06-01-2017, 07:24 PM.
These are reasonable nice if you happen to get the exact model shown:
https://www.banggood.com/10pcs-DCMT0...rmmds=category
It appears that banggood and two dozen of ebay sellers have the same supplier. If one of them sends you slightly different but inferior insert then you are going to get them from all of the sellers.
I have more than 20 boxes of wrong dcmt and ccmt inserts when I have tried to get the "good" ones. After a complaint I have got refund from all of those, 200 free inserts but not the model I want..Location: Helsinki, Finland, Europe
So which would give the better finish CCMT or DCMT?
CCMT would seem to be stronger but DCMT can get into tight spots. Is there any other difference?
I can use my TMNG for roughing, just need something for a good finish on most materials.The shortest distance between two points is a circle of infinite diameter.
Originally posted by loose nut View PostSo which would give the better finish CCMT or DCMT?
For very light cuts and good finish the dcGt and ccGt are usually super-sharp inserts for finishing and turning aluminium/non-ferrous material.
( xxG versus xxM is actually tolerance code, but in practice the G-inserts in lathe are almost always sharp finishing inserts)
http://www.carbidedepot.com/formulas-insert-d.htm
And DCMT/DCGT gets to to tighter spots but CCMT/CCGT is more usable to small boring bars.
TNGG would be the sharp version of TNMG.
If I were to choose only one finishing insert from banggood it would be this or one of these :
https://www.banggood.com/10pcs-CCGT0...l?rmmds=search
(is there some other difference than box color and price??)Location: Helsinki, Finland, Europe
I use CCMT inserts for most of my turning in steel and aluminum. It generally does a good job on either material at 750 to 1200RPM. I use CCGT inserts for finishing on either material too. The CCGT is supposed to be just aluminum but I find it works nicely on low depth of cut on steel as well and is sharp and raked enough to take shallow cuts without just rubbing. My CCXX holders are 1/2" for best rigidity letting me take 0.1 to 0.150 of diameter per pass. If space is more constrained I tend to switch to the TCMT/TCGT holders and inserts at 3/8". The behavior and finish they produce is on-par with the CCXX inserts of the same tolerance and material/coatings.
I have invested in a couple of DCMT/DCGT holders and inserts for when space and clearance are tight.
My 10x22 handles carbide tools just fine and I prefer to spend a few dollars on inserts than spend afternoons grinding and sharpening HSS toolbits.
Is the TNGG basically the same as a CCGT but except for the shape. Will TNGG they won't fit into the holder for a TMNG if they are the same size.The shortest distance between two points is a circle of infinite diameter.
Originally posted by loose nut View PostIs the TNGG basically the same as a CCGT but except for the shape. Will TNGG they won't fit into the holder for a TMNG if they are the same size.
Second letter is the clearance. N = None and C = 7 degrees. That clearance means all 3 sides slope from top to bottom by the specified degrees.
Third letter is the "tolerance", which I think of as possible variation when swapping inserts. M = tip can be .002-.005" off. G = tip can be .001" off. I think of it as Molded and Ground, since the G typically has been ground to get it within specs.
Fourth letter is the hole for mounting and the chipbreaker. G= chip breaker on both sides, so it has to have zero clearance. Theoretically you can't have a TCCG insert. It also has a cylindrical hole in the middle. T= single sided with chipbreaker, hole in the middle that is countersunk.
Now to use that.... The tool holder specifically for TCGT inserts should be cut back enough to provide clearance while still supporting the full outline of the insert. A tool for TNGT should take into account that the insert has straight sides and so the tool needs a bigger base to support the tool fully. KIn hobby use the same tool holder is used for any TxxT insert.
Originally posted by MattiJ View PostThere is no such a thing as TNGT, the double sided xNxx does not use tapered haed screw.
But you are right that double sided are not supposed to have countersunk mounting holes.
This is a metric insert on Bang Good CCMT09t304-pm. Ok I get what most of it means but what does the -PM on the end mean. I looked it up on Carbide Depot and it doesn't have any explanation. Bang Good has several similar inserts but with these different letter on the end???
Can they be ignored???
P.S. for those guys that shop on Bang Good do the prices for inserts mean for 10 inserts for the quoted price or for individual insert but in packages of 10 which is how other places tend to sell them.The shortest distance between two points is a circle of infinite diameter.
Hi,
I ignore the -pm myself. Perhaps it has something to do with coating? All 7 boxes I have ordered of various types were priced per box of 10. Dirt cheap and good enough for HSM. I've been impressed with the DCMT and ER11 threading inserts.
Sad when carbide inserts are cheaper than grinding HSS.
DaleeIf you think you understand what is going on, you haven't been paying attention.
