I have seen a large Fix Perfect shell mill for sale at a good price. The problem is that I cannot find information as to which inserts it uses and the part number of the insert pins that it uses.
It is new old stock approximately 6" diameter with a part number of MS 50884D.
We already have a 63mm Kennametal 3 tip and a Hertel 80mm 6 tip which use different tips and pins and if the big one had some common parts, I would go for it. It would make a good fly cutter with just 2 tips in it, I think it can hold 12.
I haven't been able to find an old enough Kennametal catalogue.
