Rejuvenating an old turret press just for fun. It is a fairly primitive machine and it relies on oil being applied to several points, as was common back in the '30s. I'm not contemplating running tiny tubing around and installing a Bijur oiler, but I am going to replace the 7 oil cups on this machine, either with new ones the same size or with a better solution if there is one. The ones I have have been painted at least 3 times by a meatfisted painter who was probably hung over. They only open about 15 degrees (sorry, don't know what that is in metric).
So before I order a small pile of GITS oil cups, is there something else I should consider?
metalmagpie
metalmagpie
