I was cleaning up the R8 shank on a 3" boring head the other day. I had the head mounted in the lathe so I could polish some of the imperfections out of the taper and shank. I noticed right off as I was spinning it that the arbor was out of center and the end of the arbor was turning eccentrically. Almost like the arbor wasn't mounted square to the head. I know these arbors screw into the head but I'm wondering will this have any effect on the accuracy of a hole that is bored??? or doesn't it matter??
Will it cut an eccentric or tapered hole???
JL................
JL................
