My craftex 10x18 lathe doesn't offer access to the shear "pins" shown in the drawing without total disassembly of the feed box, and probably feed screw removal too. Pretty dumb. I'm going to assume the pins are steel and may not be prepared to shear before my change gears shed some teeth. I want to figure out a solution that will guard my gears without a major teardown.
Looking at the change gears, there are lots of keyed shafts that I could easily replace keys on, removing the sturdy steel one for some weaker material so it will fail if I crash.
Thing is I'm not sure of a good material that will shear vs. mush and maybe not release the shaft, but also not wear out in a week. I also am not sure which key to replace but seems like the key for the gear on the opposite end of the feed screw should be subject to the same torque a pin would be, probably a sensible choice.
Brass square stock maybe? Any ways to test before the bad day happens?
Sent from my SM-G920W8 using Tapatalk
