My experience with hardening is limited. But I may want to make a punch and die for use with sheet aluminum (1/16" thick or less). I will need some shapes that are more complicated than a simple circle so I would need to machine those shapes in both the die and punch before hardening. I am thinking about some relatively small holes to start with, probably in the range of 1/2" to 3/4" (12 to 19 mm). My grinding equipment and skills are limited, so I would like to keep the after hardening grinding to a minimum. So, what would be the best, heat treatable alloy to use for minimum changes in size and/or shape?
I don't have an oven so I would probably need to heat it with a torch and then quench. So keeping the hardening process simple would also be desirable.
