I cut my first taper with the taper boring head tonight. The line at the bottom of the hole is where the taper meets the 3/4"
straight hole, I actually went a little too deep.
I had to center up on the hole first since I cut it quite some time ago. I set the angle at 16 degrees and took a few cuts, then I figured out I was past the 16 degrees, so I had to figure out why. It turns out I guess I should have had it set on 8 degrees, so i had to clean up the hole to where it went just a bit deeper than I wanted but it still works fine.
I need to cut the piece of HSS in half since it starts touching at the top once the other end gets to the bottom of the cut.
I might try using my dremel to cut the HSS, It's only a 1/4X1/4.
