How do I lock the spindle? Monarch K
  • How do I lock the spindle? Monarch K
    Can't switch threaded chucks
    Make an expanding plug that fits the spindles through hole so you have a way of grabbing the spindle.
      Sorry if it sounds obvious, but did you try setting the gears to the lowest speed before trying to unscrew the chuck?
      WI/IL border, USA
        low gear is it. I do not believe any Monarch has used a threaded spindle nose since before WW2.
          Low gear it is. I am afraid this chuck has been on there for a long time.
          Looks like a spindle brake is going to be a project.
            Good point. Miner, are you sure it has a threaded spindle and not D1-6?
            WI/IL border, USA
              the spindle brake should be the up position on the clutch control rod.
