I have an old 'camelback' drill I've been"working on" (more like "storing"
) for a while, and I was planning on using a typical 1750 RPM motor.
Well, to get proper belt speeds, that requires a big 12" pulley, to be driven by a tiny pulley on the motor. However, recently ran across an 1150 RPM 1HP 3-phase motor- I'd already been considering using a 3-phase for the variable speed and soft-start, and an 1150 would let me drop that 12" pulley down to a less ostentatious 8" one.
The only question is, is there any significant difference in torque from the slower motor? I'd assume nothing major- it's still a 1HP, and presumably 1HP is 1HP (unless it's on the label of an import bench grinder or a typical shop-type wet-dry vacuum.
Any reason I couldn't use the 1150 motor, or that it might not work as well?
Doc.
Doc.
