My little air compressor decided to break a reed valve this morning. Yes, it is a "throw away" machine, but the rest of it looks a feels fine, the cylinder wall isn't scored badly and, well, I want to try to fix it. I got nothing to lose. So...
I need some sort of spring steel material to fabricate a new valve (I haven't measured thickness yet). I have access to industrial shim packs at work, and the shims are spring steel. What I am not sure of is if there are different "grades" or specs of spring steel.
Has anyone tried shim pack material to make a small reed valve (est. 1/2"x 1 1/4")? Is there a better material to look for?
As with most things these days, there are no rebuild kits or parts for my model (Campbell Hausfeld HJ 300400).
Thanks,
Mark
Thanks,
Mark
