Help with compressor motor problem
  • #16
    Have you checked the pump unloader and the tank check valve?
    • #17
      I cut the air hose length in half and lowered the air pressure to 50 lbs. Tried painting again. The motor still shuts off after about 10 to 15 minutes. Its time to begin trying each of the suggestions listed above. Looks like it going to be a long, long examination and trial and error process! Sigh!!! Will answer when completed. Thanks everybody!
      • #18
        After 40 years it's probably just collected dust and grime inside the motor. Just a good cleaning would help to keep the motor cool when running.
