My mower has a cowl over the motor with a screen on the back. This screen gets blocked with grass cuttings when mowing. The weather has been dry for some time now and the screen gets blocked more often now. This causes the engine to get hot. I would like to somehow build a way to blow off the screen periodically. Mounting a compressor on the motor and plumbing nozzles to it so I can press a button and compressed air hits the screen was one method I thought about. Also I thought maybe I could mount two electric fans that would blow the grass off from the inside when I pressed a switch to turn on the fans. The motor fan sucks air into the motor compartment and that causes the grass to clog the screen. The fans possibly could be on a reversing switch so they blow air into the motor compartment most of the time and then when I press the magic button they reverse to clear the screen.....
Any ideas?
Any ideas?
