Something you don't often see set up on your mill
  • Something you don't often see set up on your mill
    Front axle for a '61 B model Mack.
    Hopefully the picture works:
    Nice!
    After you're done mount the rest of the truck up there....
    That's really great use of machinist's jacks and clamping. Very obviously one of the oh so common cases where the setup and alignment takes far longer than the cutting operation.
    Chilliwack BC, Canada
      Here's the truck:
        Damn that is nice. What sits under the bonnet.Oh forgot you guys call it a hood.
          In that picture, the stock 707 ci (IIRC correctly) Mack engine. Soon to get a Cummins diesel.
          Sid
            Nice indeed.
            The 'hood is where you park it..........
              No, I think the 'hood is where you make damn sure you don't park it!
              Lynn (Huntsville, AL)
                Nice truck , is the 707 ci a gasser
                  Yes, gas.
                    Nice set-up. Good to see a mill's table being fully used. I don't think I have even seen a photo of anything that big on a table that size.
                    Looks like you were moving the hole pattern over two or three inches and making it slightly smaller. What mounts there? Or is that the attachment point for the axle itself? If so, why would the location and size of the hole pattern change? Different frame? Different suspension?
                    PS: I like that mobile ice cream stand in the last photo. Looks like someone got clever with an air blower.
                      The reason for having it up on the mill was to make new mounting points. The center hole is to locate the spring pack, and the four other holes are for the U-bolts. The axle itself was sectioned three inches and welded back together.
                      The new axle has the proper features that he needs for the spindle that he needs to use the type of new wheel/brake package that he wants. The tires stuck out of the fenders more that he wanted, so the modification was made.
                      The "guy" is one of my brothers. Attention to detail.
                      Sid
                        Here is what the truck looked like before he modified it:
                          You don't park near your house?
                            That Mack bulldog hood ornament is unique, complete with it's own US design patent.
                            --Guido
                              The biggest thing I had on my First Mill.
                              A belt vulcanizing press...about 7 feet long, 20 or more inches high, about 9 inches thick..
                              Had to bore out holes in the ends and make bushings...
                              Good job it was aluminum.
