Does anybody near me know of any hidden Bridgeport type mills for sale
  • Does anybody near me know of any hidden Bridgeport type mills for sale
    I'm looking to upgrade my mill. Even though it be a tight fit I want a Bridgeport or clone mill
    Every time on comes up on local Craig's list it gets gone.
    Preferably within a 30 mile radius of Charlotte NC
    30 miles? How are you getting it home, pipe rollers and a pry bar?
    Add 100 miles to that radius and you should have a lot more opportunities.
      The mule gets tired, 30 miles there then 30 more dragging a BP
        How about a Cincinnati: https://charlotte.craigslist.org/hvo/6198882681.html
        Have you tried farm and industrial auctions in your area?
          I'm either going to have to rent a trailer or getting the mill picked up by a rollback. So that's the reason
            Yep it does
              There is a machine seller in Belmont (probably the closest) and another one in Burlington. They advertise all the time with decent looking machines on Craigs list. May need to stop by and let them know your needs if they don't have anything in stock. They appear to be buyers of shops that close up.
                Interesting I didn't see it. However my concern would be the distance between the table and the vertical headstock for drilling. Also the footprint and total weight.
                I'm planning to pour a concrete pad similar to what Keith Fenner did for his shaper
                  jdedmon91: Do you have room in your ceiling for a riser block?
                  Sarge41
                    Sarge41
                    Depends I know a standard BP or clone will fit. Just not sure of the Cincinnati because of the size and no quill for drilling.
                      The guy in Belmont has a couple of mills but a bit higher than I would like to put in a mill. Burlington is 2 hours away from my home. Kind of like to not transport that far
                      Just got a quote back on the bench mill form the seller in Belmont. It was more expensive than buying a new large PM bench mill that's similar
                        The Cincinnati is actually a horizontal, with a vertical head. It almost certainly has power feed to all 3 axis, so you can drill using using the power feed, though that's not the best for small drills.
                          Go rent one of these trailers from Sun Belt (several in your area) and you should have a pretty easy load & unload.
                          https://www.sunbeltrentals.com/equip...lift-trailers/
                          I rented one and took a 5hr drive (each way) to pick up a lathe. Got home and unloaded it myself.
                            Two hours too far? You really don't want a mill...
                              That's a 4 hour trip. Besides the day job has been 7 days a week so time is also an issue. That is why I want closer so I can do it after work.
