A while back I made some trike wheels.
Photos best describe the method.
This was the first wheel I had made.
The methods for calculating the spoke lengths and pcd of the spoke holes did not work too well.
So I made a mockup of the hub.
https://app.box.com/s/h464ooyqrgi3eumx3nfxqhdov1p1w0px
Here is the drill spindle that is held in the milling attachment. ( and in reply to Mike)
The spindle has a ball bearing at the chuck end and an oilite at the rear.
The ratio of the pulleys is about 3:1 and the motor spins at 8000 ~ 10000 rpm.
The drilling is done at the rear of the lathe centre, with a 2.2mm drill.
https://app.box.com/s/obyzljy3v8ivr8fvpozef8bdizipcjtr
https://app.box.com/s/8nli28h6vc5nzzutcqtlxb22ej3qb3ot
The motor is too small really, and I would recommend a motor rated at 200 watt or so.
I converted the old dc brush motor from series wound to separately-excited-field.
That increased the power and gave much better speed regulation.
In taking the motor apart to reconnect the field, it is necessary to keep the armature in the brush end bearing.
If the brushes pop out, it is a difficult job the get them back in. I used the pulley to retain the armature in the end bell.
https://app.box.com/s/0jky4q1e79tdl96so1dblsdg3ahgx2jo
The field curve of the motor.
https://app.box.com/s/uh5oslzm6qm2wzh94p7v8u994kmhhi84
Here is the circuit diagram.
https://app.box.com/s/41p0t9jt7e4if490yder529bjjxik97y
I have a vintage Hewlett Packard Dual 24 V supply mounted in ceiling over the lathe.
The indexing of the spoke holes is by using the 64 tooth gear on the 63:64 compound gear used for metric threading.
I made a "woodpecker", spring loaded as shown out of scrap cast iron with a beak brazed on.
The 64 tooth gear means only 32 spoke hubs can be made.
A 72 tooth gear would allow making hubs for the more common 36 spoke rims.
https://app.box.com/s/ph3cxvdx4vrwiia3l3tnfdijmf32qn3y
Here is the finished wheel.
I used the simplest "1 cross" pattern, also all spokes are on the outside of the hub.
I built the 2 smaller rear wheels in a similar way, and the wheels have been in use for 2 summers.
https://app.box.com/s/mi94bxivahw6gtuv99knwxozc01c02gi
