I am making a power control box and want to paint it. It is going to be housed in a new aluminum chassis box. I have cut and drilled all the holes, removed the protective plastic film, and it is ready for paint. I plan to use Rustoleum Metallic Gray Hammertone. I have had problems with paint sticking well to these aluminum chassis boxes in the past.
What is the best way to prepare the surface prior to painting. The can says that primer is not necessary. But is it? Or what? Rough up the surface with sandpaper? Steel wool? What?
