City of Flint.
The street here has been closed today to start the lead pipe service line replacement.
Even though the service lines are house owner property, they are being replaced by city.
I will try to get some photos as the job progresses while respecting the workers identity.
Apparently, the lack of records of which houses have lead service is a problem.
Copper lines will not be replaced.
The contractors liason person told me that they are trying a new water drill to help identify.
Here it is:
About 15 years ago, i replaced most of the internal house lines with copper using lead free solder.
The water samples taken in the kitchen are at or slightly above the EPA reporting level of 0.001 milligram per litre.
I did not replace all of the short galvanized runs to external hose bibs and to the basement sink that I now use as a darkroom.
The sink measured at 0.67 milligram per litre, (670 time limit) and one hose bib measured 1.07 (1000 times)
I have been told that all internal pipes with high readings have to be replaced.
In addition, all faucets sets ( good or not) will be replaced with brand name builder standard units.
The external hose bibs have to comply because there is a remote chance a child will drink from a hose.
This house, built 1926, has been inspected using X Ray Fluoroscopy, and has lead under most painted surfaces.
Here it is:
