CNC is kind of always thought of as a production process. I bought a large CNC bed mill at work, but I have homebuilt CNC minimill size machine in my garage. It occurs to me that with inexpensive CNC programs and inexpensive CAM to write programs that people with small machines really can get a huge benefit from CNC.
For instance I needed to make couple of sheetmetal parts with a couple 5mm holes and a 12mm hole. It doesn't matter that I don't own a drill in either size, or that my machine couldn't handle a 12mm drill in stainless. A 1/8" endmill did the job nicely.
I needed to face of some short 1-1/4" Od stainless rods. Standing up in a lathe chuck clamped to the table I programmed a spiral in from the outside to the center using a 1/4" endmill, the biggest the machine would handle in SS. Slow cutting on a small machine. Who cares, I worked on other stuff while it did the job.
Tell me you guys with tiny machines get great joy from turning cranks for hours to remove a relatively tiny amount of material? I'll bet with every turn you are thinking power feed or sending it to someone with a bigger machine. The CAM program lets me generate programs for tiny tools taking hundreds of passes in just minutes.
Everyone thinks you need ball screws and such to make it practical. Thats simply not true. If you can make a part cranking handles CNC can do the same job on the same machine. I'd like to have a tool changer, but when the goal is just to make the part and you don't care if it runs by itself for hours you start picking the largest tool that can do the snallest feature and let CAM create hundreds of passes for the big stuff if needed.
