Originally posted by Black Forest
View Post
I'm not a metallurgist, but I am a curious blacksmith. One of the best knife makers that I know, Howard Clark, developed into quite a jackleg metallurgist by asking questions that did not have obvious answers.
See paragraph 4
http://arscives.com/mastersofire/8hc.htm
Howard held a workshop at his place in the mid 90's. Aside from the fascinating demonstration of the pattern welded steel that he put on, he also demonstrated his heat treating method that was adapted from industry for use in this patten welded steel business. The salt bath process he used is not well suited to hardening and tempering in the traditional blacksmith method using residual heat to temper the hardened metal.
By heating in a molten salt bath you gain a number of advantages. You are able to control the maximum temperature quite easily. You also are heating in a medium that has a vastly higher specific heat (layman's term possibly) that heats the meal to the hardening temperature very rapidly. The blade was then removed from the high temperature salt bath (1500° or so depending on the steel )and inserted into a low temperature salt bath (perhaps 500° )
After the metal normalizes it is subjected to the same process a number of times. This refines the grain structure but maintains the Rockwell condition. An added benefit is that the metal is coated with a film of salts when it is removed from the baths that prevents oxygen from reacting with the metal.
(further reading about Howard:
http://www.mvforge.com/
http://www.knifepurveyor.com/howard_...nife_3859.aspx
https://www.facebook.com/Morgan-Vall...7129980183355/
one of my favorite knifemakers... lotsa stories.
He dropped out of the knife biz and moved to the Japanese sword world)
As regards the Forged in Fire show (besides the name... you heat in fire and forge on an anvil) and the $10,000 prize, you have to ask your self what the losers are being paid. I know one of the contestants. He had to give up a considerable amount of time to participate in the show. Regardless of outcome, which is a crapshoot given the time frame they have, what professional would give up 2 or 3 weeks of productive shop time just to be on a show. The fella I know gets very serious money for his work and did not make it past the first round.
