Tall Metric machine screw nuts?
  • Steve_Cole
    Google M3 spacers, lots of different styles, lengths and materials.
    Sent from my Nexus 6 using Tapatalk
  • sewingmachine
    In the home shop Machinist and Machinist Workshop there is listed a company called Micro fasteners. The handle Metric as well as Imperial fasteners. You might want to try them.
    Dave
  • wierdscience
    Originally posted by Ohio Mike View Post
    That seems double odd to me. An M3 should be 5.5 mm across the flats and 2.4 mm high. Is this even a 0.5 mm standard pitch?
    Standard pitch,just everything else is odd apparently.
  • wierdscience
    Originally posted by genea View Post
    Nothing 7mm across but they do have 6 and 8mm across with M3 threads, 5mm tall, and a lot of different materials.
    RAF Hardware: http://www.rafhdwe.com/metrics/inter...standoffs.html
    Now there is a possibility.
  • wierdscience
    If you need metric ****load of them I am sure that some factory will happily make 100 ton batch of m3 DIN6330 nuts... ah well, I guess you don't need THAT many
    Wouldn't that be a S---t Tonne of them?
  • Ohio Mike
    I have some M3 nuts I would like to find a source for.These are M3 diameter 7mm hex and 5mm tall.Is this a standard series in Metric fasteners?Are other sizes available?Or are these something special?
  • genea
  • MattiJ
    I'm gonna need too many to cut anything down or make anything.I was hoping to find a source for these in bulk if possible,but looks like they aren't common afterall.
  • tom_d
    I've never purchased from them, but they appear to have quite the selection:
    Maryland Metrics http://mdmetric.com/
  • wierdscience
  • H380
    Yep. What MattiJ said.
    https://www.alibaba.com/showroom/coupling-nuts-m3.html
    https://www.aliexpress.com/wholesale...oupling+nut+m3
  • MattiJ
    Din6330 comes to my mind but finding those in m3 size might be tricky. Another option is to cut down from longer "coupler nuts"
  • boslab
    Not sure, if your stuck use m3 hex spacer and cut a pice the size you need and screw some 3mm thread bar in, I've used 2 nuts to get a deep head a few times too, 7mm head sounds a little deep
    Mark
  • wierdscience
    started a topic Tall Metric machine screw nuts?
