Greetings! Just had the motor in my 30-year-old table saw seize. Motor is 3HP, single phase. One bearing (25/52/15mm) was shot, the other seemed good. Replaced shot bearing, cleaned and re-greased the other, and reassembled. Motor now runs smoothly when first started, then an audible vibration starts that lasts 20 or 30 seconds, then goes away, then comes back ... I have only one clue to the problem: if I tighten the 1/4" bolts that secure the end bells to what I would consider a normal torque, the shaft seizes. If I back one or more of the bolts off little by little, eventually the shaft frees up. By then, at least one bolt will be only a little more than finger tight.
My not-so-local motor repair man says that the problem is probably warped end bell(s) and that sleeving and re-boring the end bells would cost about the same as a new motor, not to mention 4 hours off driving to drop-off/pick-up.
So, my questions are:
1) Does this sound like an end bell warpage problem, or something else?
2) If end bell warping,
a) how can I tell which end bell is the problem (or both)
b) how to set the work up accurately on the lathe for boring, sleeving, and boring to size? (The end bells are not-very-meaty aluminum castings.)
c) instead of repairing the bearing seat, would it be easier to turn a plug mandrel to the bearing OD (52mm), press the end bell onto the mandrel, then turn the end bell mounting flange to be concentric with the mandrel/bearing seat, and make up paper shims to space the end bell out to its original location?
Thanks for your suggestions.
JA
JA
