While reading another thread where the advantages of ball screws was brought up, I have to wonder. I can see the advantage of zero backlash. And they may be more accurate, but there are some very accurate acme screws. But an acme screw will wear over time and use. So, wouldn't a ball screw, which relies on a number of small areas of contact between the balls and the screw, also have wear over time and with use? The balls would contact only a very narrow track on the screw and nut so wear may be more rapid. Won't it come to a point where it will have more wear at some points and backlash and need to be replaced, just like an acme screw? How does the operational life of a ball screw compare with that of a conventional acme screw?
Is it that the number of balls in contact with the screw and nut is large enough to provide a similar amount or even larger amount of contact area? Or are they just made better? Hardened? Better steel? Or what?
