first valve now burner question
  • first valve now burner question
    I posted a ? about how to make a valve and got some very good advice, so good I made a simple one and it works, but now I need some help on the burner. It burns like a candle, and lacks the blue intense flame of the handheld butane torch I took the burner tip (pictured below, hopefully) from. I am using the same fuel so what is wrong? Any help is needed. Scott.
    http://lathegear.com/13cc24e0.jpg
    \"Be skeptical of any perpetual-motion proposal in which the assumed motion causes no change in the position of the center of mass of any part of the system\"
    Try picture again:
      It appears that it's burning just the fuel and no oxygen (air) is being added to the flame to give it the characteristic blue color. Least that's how it looks.
        I suspect you are right, this was suggested on another forum but how would I get air into the mixture? The only way I can think of is to drill some small holes around the tube by the burner tip. I wonder if this is a pressure problem too. The original torch had a very small orafice in the supply tube, I don't have a drill that small anymore, Scott.
          Small drill BIT that is... can someone tell me where the edit button is on here?
            The burner in backyard casting's page is a piece of 3/4" pipe with 7/32 holes drilled in it to add air.. It has a flare or funnel on the end, when a burner is outside the furnace it must have a sheetmetal tip to make the flame look right.
            http://www.backyardmetalcasting.com/ the site...
            No connection..
            [This message has been edited by ibewgypsie (edited 11-11-2005).]
              http://www.backyardmetalcasting.com/rolledflares.html
                Aha! You have answered my question in more ways than one with that link. I have very little pressure to pull the air through the orifices (I checked and the tip does havem) on the tip. I need to put some sort of reducer in-line by the burner tip. Plus a shroud. Appreciate the help, ibewgypsie.
                Scott.
                  I put a weed burner in one furnace.. I got it on sale less than $20.. took a tubing bender and folded a 90 on the end.. I first used it under grandma's old iron pot to cook some food...
                  I think I remember Spence using the same deal..
