Originally posted by flylo
View Post
Got my start working on the old air cooled VW's and they and penzoil did not mix,
so many time's would go to do a valve adjustment - drop the covers and all kinds of layers of flaky scaly crud would fall out onto the floor, rocker arms not even recognizable --- would then ask the owner what they were running and 9 times out of 10 penz was the reply, the occasional quaker state was the other answer to the question, it was not a whole lot better,
Valvoline was superior that way - never a problem it's all we used...
nothings tests engine oil like an air cooled engine in my mountainous state...
I have had guys with tractors tell me penz is all they used and they never had a problem - that's fine - just don't run it in air cooled car engines going up mountain passes, your tractor is so underpowered and it's got water cooling is the answer to how you got by running an inferior engine oil...
that's back in the day - penz has evolved some...
