First dovetail cut!
  • First dovetail cut!
    I'm working on a toolpost for the Schaublin 102 and I cut the dovetail with my Ammco shaper. First time I've done this:
    I was pretty happy with how it turned out. Initially I thought about just buying a dovetail cutter, but I decided against it and put the shaper to work. I'm glad I did. I didn't have to buy the cheap dovetail cutter that may have had questionable life in 4140 HT and it forced me to learn a few things along the way.
    www.thecogwheel.net
    Fun isn't it? One of the most fun tools to run.
      Very nice ... well done.
        Looks like a dove's tail to me. Good job!
        Make it fit.
          Thanks guys!
          Just cut the mating part:
          www.thecogwheel.net
            MLA type toolpost - nice.
            Shaper dove tails - good fun innit? And a lovely finish.
            Now you'll have to make most details of the holders in the shaper too.
            Get rid of those 'orrible end mill marks....
              I can hear the scraping of the steel. I like the use of the scraper or shaper. JR
              The sound of it shredding metal off in layers or chips. Love that...
                Very nice, well done! +1 for shapers.
                Did you leave the clapper box in line with the toolslide, or did you set it a bit further over? If you set it a few degrees further over, the tool clears the cut face better on the return stroke.
                Ian
                All of the gear, no idea...
                  Wow! Nice tool porn!
                  What about a gib?
                  Edit: Never mind, it's a tool post.
                    Good eye! It is closely based on the MLA-23 design with some changes. I scaled the design down for the Schaublin, and made the body out of 4140 HT round instead of 4140 square. The tool holders are smaller as well.
                    www.thecogwheel.net
                      Ian
                      I did have the clapper set over, but I think it needs to go more as you suggested.
                      Shaper work is fun!
                      www.thecogwheel.net
                        Very nice. Cutting a dovetail is something I haven't done yet on my milling machine. One of these days, I will get brave enough or bored enough to actually buy a cutter and try machining a dovetail.-I don't have a shaper, and have no plans on buying one, but I remember well a number of large shapers running in the manufacturing company I grew up in in the mid 1960's.--Brian
