Bridgeport clone attributes
  • platypus2020
    We had a massive Tree mill at work, looked like a Bridgeport on steroids
  • Toolguy
    Webb, Sharp, Kent and Summit are all good machines as well.
  • wierdscience
    Sharp offers some good machines as well-
    http://www.sharp-industries.com/manual-machines/74/3
  • GNM109
    There are many clones that continued to evolve the basic BP design which stopped on the 70's with the varispeed head. The heavy version is the VH4 (generic base type, many names) with box ways, bearing to support the bottom motor pulley, more Y, more Z and and a host of incrementally better features. oh.. weigh in nearly 1000lb more than the typical BP.
    Correct on all points. I have a Taiwanese 3VH Webb Mill. It has the features you mention, including the extra motor bearing, 3 hp induction motor, Box Ways, central oiling and weighs in according to the literature at 3,500 pounds. According to the people at Webb where I got my parts when I was refurbishing it, they use the Meehanite cast iron process for all of the castings. It's a 10 X 54 size. I use a Chinese X servo on the X axis that I bought from CDCO and I also have a 2 Axis Mitutoyo KA DRO with a Mitutoyo scale on the Z Axis. It was formerly a CNC machine and I converted it back to manual so I kept the ball screws. There is almost no backlash on either axis.
    Webb is still very much in business and stock all of the parts for the machines that they sell.
  • Rich Carlstedt
    Plus one on the Acer.
    If I was ever to lose my Bridgeport , I would opt for a Acer . Their scraping skill level is higher than the average apple
    Rich
  • Toolguy
    The Acer E-mill shown by H380 is one of the best ones out there. Sometimes a used one will be under $6000.
  • akajun
    All three of my Laguns have Dovetail ways. Never even heard of one with box ways. They are about 500-1000 lbs heavier than a BP depending on model and in my opinion more robust. The design of the high low selection on the head is better as well.
  • QSIMDO
    Those heavier built mills you are referring to are copies of
    the Bridgeport series 2 special. It has box ways and is
    stronger built in every regard. Lagun in Spain copied this
    design and changed it some, even offered a 40 spindle taper.
    I think this is what most China makers copied.
    -Doozer
    Any tips on detecting excessive wear on box ways vs. dovetail?
    Never seen one in person actually.
  • Doozer
    -Doozer
  • flylo
    H380, that's a great price on a very good machine IMHO.
  • H380
    My local dealer.
    Acer Electronic Variable Speed Vertical Mill - R-8 Spindle - 9 x 49'' Table Size - 3HP - 3PH - 220V Motor $7740 + Shipping. Check your local machine dealers you might be able to get close to your price on a demo or misordered machine.
    http://www.rex-supply.com/cgi/CGP2SR...68157601714207
  • Arcane
    Originally posted by QSIMDO View Post
    I'm going to stay in the sub $6k range.
    Surprisingly a bit tough around here with clapped out going for up to $3-4k and refurbs at $9k-ish on up.
    I decided to spring for new when I bought my BP clone (made in China and claimed to be 2223 lbs)...and it just struck me that it's getting to be almost 20 years old now! Back than it was $8,100 including taxes. I figured that was just a few years of what some people spend on cigarettes with nothing to show for it.
  • QSIMDO
    Originally posted by H380 View Post
    Acra and Acer are great also. The larger mills have square ways not dovetails that always seam to be cracked on old Bridgeports. They are much heaver also. For what a new Bridgeport cost ($15K to $17K) you can get a 5hp, #40 spindle, DRO, 50x10 table and 3 way power feed and still have money left over. Like others said they are a different class of machine.
    http://www.aceronline.net/acergroup/em-5vk.htm
  • H380
  • lakeside53
