Can you use stainless bolts in galvanized metal will they react with each other am redoing the boat trailer? Also have a pin hole in clutch cover on motorcycle will epoxy stand up to 250 degrees , this is a defect in the casting and a good chunk of change, would be nice if I could just epoxy it .
Thanks Richard
Thanks Richard
